New RegistryEx Plug-In for Enumerating Keys, Values
sinan
Post by sinan »
A new InstallAware plug-in has been furnished by Andy Neillans.
Called RegistryEx, this plug-in enumerates subkeys of a registry key, or values of a key. It stores the results in a variable, delimited with a character of your own choosing. You may then parse the results using Parse String.
This plug-in makes it very easy to obtain a full list of locally installed SQL Server instances, and reading all other types of data from the registry where enumeration is required and no knowledge of pre-defined keys/values is available.
Andy, thank you very much for making this great plug-in available!
Sinan
Download File:
http://www.installaware.com/forum/oldat ... 0regex.exe
Treoxx
Re: New RegistryEx Plug-In for Enumerating Keys, Values
Post by Treoxx »
Great plugin, many thanks for this..
I only have one issue:
On 64 bit system, RegistryEx only search in the 32 bit registry area (Wow6432Node), it does not react on the Set x64 installation mode.
Did I missed something or is it just for 32bit?
sdolan
Post by sdolan »
Does anyone know if this plugin works with InstallAware 9?
I really need a way to enumerate a registry key, but it needs to work for 32 and 64 bit win XP/7
