Hi Francesco,
I need to create a GUID in the installer. I found a plug-in that one of the users developed, but it gives an error when I'm trying to use it.
Is there any other built-in way to create a GUID?
Regards,
T.
Create GUID
Re: Create GUID
Error message:
"Failed to compile plug-in action: Generate GUID"
Re: Create GUID
Fixed.
I'm including the fixed IDE dll for anyone that is using the Generate GUID plug-in
Regards,
T.
Regards,
T.
- GenerateGuidIDEPlugIn.rar
- Fixed GenerateGuidIDEPlugIn.dll
- (86.14 KiB) Downloaded 2002 times
Re: Create GUID
Dear Tzachk,
Many thanks for your post. I believe it can be useful for many other users.
PLEASE NOTE, this topic has been moved to Plug-In Development forum.
Users browsing this forum: No registered users and 1 guest
