Component folder
devdept
Component folder
Postby devdept » Thu Feb 24, 2005 4:32 pm
I am evaluating ia3 and don't understand the following:
File section:
* I have all the app files under the VS2003 Release folder and want to copy them under the specific Component folder, for example $PROGRAMFILES$\\My App\\My Component. How can I add the files to the specific dir that - of course - isn't listed and there is not any specific Add New Folder button? :roll:
Should I add the Release forlder and after - in the code view - change the destination folder name?
Thanks a lot,
Alberto Bencivenni
devDept Development Team Leader
Structural Optimization | Finite Element Method | Computer Graphics
sinan
Postby sinan » Fri Feb 25, 2005 6:18 pm
Yes, that is exactly how to do it. Except, you don't need to swap back to the code view. Just add the file, then double-click it and type in the new folder name while still in the visual view.
devdept
Postby devdept » Sun Feb 27, 2005 11:08 am
I was right...
Thanks a lot, what about changing the single EXE setup icon?
Thanks again,
Alberto Bencivenni
sinan
Postby sinan » Sun Feb 27, 2005 1:53 pm
Easy, Project Options window. You can load icons of any color depth and pixel size.
devdept
Postby devdept » Mon Feb 28, 2005 4:08 pm
Mmm... isn't it the Add/Remove icon?!? I was speaking of the setup.exe release file.
Alberto Bencivenni
sinan
Postby sinan » Mon Feb 28, 2005 6:05 pm
It's used in both places, actually.
Users browsing this forum: No registered users and 23 guests
