Validate Drive Plug-In (FREEWARE)
mathim
Postby mathim » Sun Jan 24, 2010 12:20 pm
PURPOSE:
Validate Drive Plug-In Validates Drive\\Folder and checks if 'X' amount of space is available.
WHY:
Offers an easy, fast and convenient alternate method instead of writing multiple script commands.
USAGE:
The Drive\\Folder Path field is the variable containing the drive path to validate.
The minimum free space field is the amount of space required. This is an integer value in kilobytes.
The results field is the variable to receive the validation status.
RETURN VALUE:
The return value will be TRUE if the drive is valid and space requirements is satisfied, otherwise FALSE is returned. One exception is if the user leaves the field completely blank - no value entered in the dialog box. In this case the return value will also be blank. So when testing for failure don't use FALSE instead use NOT EQUAL TO TRUE to include the blank return value as a failure.
Any problems, suggestions or comment can be sent to email address below.
Regards,
Mickey
mickey@mathieson.ws
Download File:
http://www.installaware.com/forum/files ... lug-In.exe
Users browsing this forum: No registered users and 2 guests
