Assigning Variables to Themselves
Postby MichaelNesmith » Mon Jul 20, 2009 4:52 pm
When you do that, you're triggering an infinite loop! Never set a variable to itself.
Tiago
Postby Tiago » Tue Jul 21, 2009 5:51 am
Infinite loop? Damn...
Well, I fixed the problem by writing to a file and then reading it into a variable. Is there any way to add one string to the end of another without calling its name inside the Set Variable statement?
Thanks in advance.
Postby MichaelNesmith » Tue Jul 21, 2009 6:06 am
Actually, I take that back...looking in InstallAware code, we find:
Set Variable PRELIST to $PRELIST$$NEWLINE$Previous Version Uninstallation
So I think this limitation might have been already transcended - or might have been introduced in a bug during an interim build. What version of InstallAware are you using?
ALive
Postby ALive » Tue Jul 21, 2009 6:16 am
Hi!
If I understand your discussion correctly we cannot use:
Set Variable LIST to $LIST$$NEWLINE$$NEW_LINE$ ???
such method is used in the PREREQ list:
Set Variable PREREQ to TRUE
Set Variable PRELIST to $PRELIST$$NEWLINE$Microsoft Windows Installer 3.1
correct me if i'm wrong...
Tiago
Postby Tiago » Tue Jul 21, 2009 6:17 am
I'm using InstallAware Studio 9.
Yeah, I've seen that line too and thought that would work for me. Anyway, I have noticed the problem happens only in the second time I call the variable inside its own Set statement. The first time I use it, when the variable is still blank, everything runs fine.
Well, that's what happens to me.
Thanks for the responsiveness.
ALive
Postby ALive » Tue Jul 21, 2009 7:08 am
Still... this seems weird to me.
I also use such mechanism. Moreover it is a common practice in many program languages (C++, C#, e.t.c.) to reassign a variable.
Ho long is the list you are trying to show? Maybe it's too long?
I don't think using temp file for writing is a "good practice". Because in certain situation you can encounter a write access problem or something.
Anyway, try to print this $LIST$ variable via MessageBox. Maybe there's some unprintable symbol??
B.t.w. do you use localizations?? I know some issues that can take place if using localization unproperly.
Copy/Paste the code you are using (Using Ctrl+Shift+C).
Tiago
Postby Tiago » Tue Jul 21, 2009 7:34 am
Yeah, I know that reassigning a variable is a common practice in regular programming languages, and yeah, this is a quite weird situation I'm having here.
The list is intended to show the names of all the features selected by the user in the componentstree dialog. I don't think is a string length matter, once the same string can be read from a file without any problems. I don't think it's a good practice either, but it's the only way I managed to make it work so far. I have considered the unprintable symbol hypothesis, but that's not the case. The only special symbols I'm using are "-" and " " (hyphens and spaces). And no, I'm not using localization.
The code I used is as follows:
Get Component Server Side Selection State into Variable SELECTED
  Set Variable LIST to SERVER SIDE
Get Component Server Side\\Shared Folder Selection State into Variable SELECTED
  Set Variable LIST to $LIST$$NEWLINE$   - Shared Folder
Get Component Server Side\\Database\\Main Selection State into Variable SELECTED
    Set Variable LIST to $LIST$$NEWLINE$   - Main Database
Get Component Server Side\\Database\\Integration Selection State into Variable SELECTED
    Set Variable LIST to $LIST$$NEWLINE$   - Integration Database
Get Component Server Side\\Database\\Gateway Selection State into Variable SELECTED
    Set Variable LIST to $LIST$$NEWLINE$   - Gateway Database
Get Component Server Side\\Application\\DCM License Selection State into Variable SELECTED
    Set Variable LIST to $LIST$$NEWLINE$   - DCM License Application
Get Component Server Side\\Application\\Alarm Selection State into Variable SELECTED
    Set Variable LIST to $LIST$$NEWLINE$   - Alarm Application
Get Component Server Side\\Application\\Gateway Selection State into Variable SELECTED
    Set Variable LIST to $LIST$$NEWLINE$   - Gateway Application
Get Component Server Side\\Application\\Integration Selection State into Variable SELECTED
    Set Variable LIST to $LIST$$NEWLINE$   - Integration Application
Get Component Server Side\\Application\\Monitor Selection State into Variable SELECTED
    Set Variable LIST to $LIST$$NEWLINE$   - Monitor Application
Get Component Server Side\\Application\\View Web Selection State into Variable SELECTED
    Set Variable LIST to $LIST$$NEWLINE$   - View Web Application
Get Component Client Side Selection State into Variable SELECTED
    Set Variable LIST to $LIST$$NEWLINE$ CLIENT SIDE
Get Component Client Side\\Application\\File Manager Selection State into Variable SELECTED
    Set Variable LIST to $LIST$$NEWLINE$   - File Manager Application
Get Component Client Side\\Application\\MWS Selection State into Variable SELECTED
    Set Variable LIST to $LIST$$NEWLINE$   - MWS Application
Get Component Client Side\\Application\\View Web Selection State into Variable SELECTED
Postby MichaelNesmith » Tue Jul 21, 2009 7:43 am
I think I see where the problem is. $LIST$ might even be undefined when you are assigning it to itself. Try to set $LIST$ to something empty, see if that fixes the problem.
When you do this:
LIST=$LIST$ + Something Else
as long as at *that* point of assignment, $LIST$ is something that excludes $LIST$ itself, you'll be fine :) Otherwise, you end up in an infinite loop. Because LIST is always something plus $LIST$ and you don't know what $LIST$ is at that stage.
Does that make sense? :D
Tiago
Postby Tiago » Tue Jul 21, 2009 7:54 am
Kinda :P
In regular languages, the result of concatenating something with a null string would be the production of a null string, not an infinite loop. Well, at least we now know about this MSICode particularity. Anyway, my project schedule is a bit overdue, so I'll try your suggestion later.
Thank you very much for the advice! :D
Postby MichaelNesmith » Tue Jul 21, 2009 10:05 am
Yeah, the problem in MSIcode is, when you do an assignment before the variable is defined, its not even null.
For instance, this is OK:
VAR = $UNDEFINED_VAR$ + $DEFINED_VAR$ + CONST
The result will be:
$UNDEFINED_VAR$ + <VALUE> + CONST
But this is not:
$UNDEFINED_VAR$ = $UNDEFINED_VAR$ + CONST
Because the $UNDEFINED_VAR$ variable is totally unknown at that point and cannot be even substituted in literal form as in the "OK" sample above - it will blow. This can be solved as easily as setting it to an empty string, of course :)
Tiago
Postby Tiago » Tue Jul 21, 2009 11:13 am
Sure!
Thank you very much for the clear explanation, Michael! :D
ALive
Postby ALive » Tue Jul 21, 2009 11:48 pm
Yeah, thank you Michael!
I think this topic could be marked as a sticky. Or create a separate thread with proper header and with your description applied.
Thanks again!
Users browsing this forum: Google [Bot] and 23 guests
