I am having some test failures when trying to run the Vista certification tests - document "Certified for Windows Vista Test Cases", Version 1.3.001, March 6, 2007.
Specifically the failures are to do with the following tests:
Test 12 - Verify application’s MSI installer does not receive any errors from the Internal Consistency Evaluators.
Problem: Errors 30, 33, 60, 74 & 84 are present in the output
Test 14 - Verify application launches with installed user token
Problem: Installer is executed as “highestAvailable”
We are using version 7 release 2.
Can you assist?
John Davies
Vista Logo Testing
Users browsing this forum: Google [Bot] and 37 guests
