Windows Firewall Plug-In
The Windows Firewall Plug-In allows you to add or delete exception rules for the Windows Firewall in your setup.
More information and download is here:
If you have any comments, problems, suggestions please post to this thread.
Martin Rothschink
AxoNet Software GmbH
Hi Martin;
I installed your firewall plugin. Thanks VERY much for creating this for the community.
I am hoping that you can advise me on how to handle this particular firewall configuration problem via your plugin.
I see in your plugin that I can specify what installed application I need to create an exception for. However, what I am trying to do is essentially turn off the firewall (or create an exception) for the IA installation itself.
I know that this is not a very clear explaination so perhaps an example would be of benefit.
While IA in in the process of installing my application, I need to run an SQL script to create a database, however I need to turn off the firewall (or create an exception) prior to when InstallAware runs the SQL Database creation script (via IA's SQL Databases feature).
So the installation steps would be:
> run the InstallAware setup to install 'MyApp'
> turn off the firewall or create an exception for the running InstallAware process.
> Run my SQL database creation script during the InstallAware install of MyApp. NOte that InstallAware connects to the SQL Instance at this point in time in order to generate the DB.
>(optionally) turn on the firewall again or remove the InstallAware process excpetion.
In your plugin I can specify my application name for the purposes of creating an excpetion, however would only be of benefit in the future, when my application has been installed. How would I specify that it is InstallAware that needs to be granted the exception during the InstallAware installation process?
Steve,
first try to use the ports from Jims post.
If this doesn't work you can try to create an exception and use $EXEFILE$ as the program. Put this command in front of your SQL action.
After your SQL action delete this exception rule:
~InstallAware Clipboard Data~
~Firewall~
~{890B7CF9-3ECE-4D94-AD1F-7EF4AABD7E19}~
~0,"$TITLE$ setup",0,$EXEFILE$,,0,0,,3~
~FirewallIDEPlugIn.dll\\FirewallIDEPlugIn.dll~
~Firewall~
~1,"$TITLE$ setup",0,$EXEFILE$,,0,0,,3~
Martin Rothschink
It should work for incoming rules in the Windows Firewall in Vista.
Vista has added outgoing rules which you can't configure with the plug-in.
Martin Rothschink
Hi Martin,
Thank you very much for your contributions.
Iwas checking the Volume Info Plug-In, and would like to suggest including the return of the UNC path from the volume, I think this would be useful. I am playing with the API function WNetGetConnection to get this value, but after looking at your plug-in thought that this function may fit very well in this plug-in.
Edhy Rijo
Edhy,
I have enhanced the volume info plug-in to return the UNC path name.
http://www.axonet.de/eng/Axo/plugins_fo ... laware.htm
Martin Rothschink
Firstly, thanks for an excellent plugin and making it available to the public.
I am using version 2. 1.0.20 and the plugin does not appear to work for Vista (x64). I have not tested it on 32 bit versions of Vista. The user that is running the installer is logged in as an administrator. I am trying to add a program exception and the exception does not appear in the firewall exception list. Here is the installaware code that I use to add the exception:
Any help would be greatly appreciated. thanks!
~Windows Firewall~
~{BE0C043C-A2CF-4566-8B8F-C7847EEAC2A2}~
~0,MyApp.exe,0,$TARGETDIR$\\MyApp.exe,,2,0,,3~
~FirewallIDEPlugIn.dll\\FirewallEXEPlugIn.dll~
Ryan, I made a test in x86 mode and in 64 Bit mode on Vista 64 and found no problems with the plug-in.
Please check: have you placed the call to the plug-in after Apply Install?
Is MyApp.exe installed before you call the plug-in?
Martin Rothschink
1. the call to plugin is made after apply install, so MyApp.exe is already installed in it's target folder during the call.
With regards to the questions in your PM:
can you give me some more details? You have build a 64Bit Installer?
- I have built a hybrid win32/x64 installer that detects the type of os and sets installation mode to win32/x64 as necessary.
Basically the sequence of steps (for the failure)
1. set installation mode to x64
2. run gui / specify files to install
3. apply install
4. configure windows firewall
What problem do you have?
- After making the call to the configure windows firewall plugin, the exception is not present.
What version of Vista x64?
Vista Business x64
3. apply install
Vista Business x64
Vista/64 Cannot add Port to Firewall Exception List
All,
Just checked to see if anyone has added a Port exception using this plug-in under Vista/64.
I can add applications just fine.
Works find under XP.
That's on my list for a later version. Can't give any schedule right now.
Martin Rothschink
Users browsing this forum: No registered users and 1 guest
