writing into INI-files
lemke
Postby lemke » Tue Dec 14, 2004 11:30 am
With some worarounds I'm able to add a new value to an existing key within a inifile. If I uninstall the product unfortunatelly not onle the single value will be deleted but the hole key becomes deleted.
How can I influance the uninstall routine?
I the a way to solve the problem except to write a own DLL which is doing the work for me?
Stefan
sinan
Postby sinan » Tue Dec 14, 2004 3:15 pm
I'm not sure what you mean by the workarounds :)
There are several possible values for editing INI entries:
    Line->Create or Update
    Line->Create Only
    Line->Remove
    Tag->Add
    Tag->Remove
Which of these did you try?
It seems to me you want the Line->Create or Update option...
The Tag options add values to an already existing value (ex: VALUE=DATA1;DATA2, etc.)
lemke
Postby lemke » Wed Dec 15, 2004 7:34 am
You are right I used the wrong action. I have to use Tag->Add.
Stefan
Users browsing this forum: No registered users and 194 guests
