I'm using non-modal Dialog progress in my script and then displaying a modal dialog box.
50: Display Dialog: progress, use as progress dialog (non-modal)
100: Display Dialog: db_settings, wait for dialog to return (modal)
The "db_settings" dialog has Back, Next, and Cancel button enabled. But Back button doesn't work.
"if Variable WIZARD Equals BACK" check doesn't work because WIZARD is set to NONMODAL. I tried adding 'Hide Dialog' before displaying "db_settings" dialog and also "Set Variable WIZARD to NEXT" but that didn't help.
Any suggestion, what I'm missing here.
Back/Cancel button on Modal dialog after non-modal
Re: Back/Cancel button on Modal dialog after non-modal
Issue resolved. programming error.
We forgot to save return result in WIZARD variable in 'Display Dialog' UI.
ExchA
Users browsing this forum: No registered users and 32 guests
