using IA X2 build 4.03.15 on win 7 64-bit
These commands don't work anymore from previous installer:
Run .NET Installer Class $TARGETDIR$\emailroutersvc.exe
Run .NET Uninstaller Class $TARGETDIR$\emailroutersvc.exe
If I comment these out in my code and replace with this it works fine.
Run Program $WINDIR$\Microsoft.NET\Framework\v4.0.30319\InstallUtil.exe "$TARGETDIR$\emailroutersvc.exe"
Run Program $WINDIR$\Microsoft.NET\Framework\v4.0.30319\InstallUtil.exe /u "$TARGETDIR$\emailroutersvc.exe"
Where and how is your installer class getting the path to the installutil.exe?
Run .NET Installer Class doesn't work
Re: Run .NET Installer Class doesn't work
This explains why some of my sites (not all), services never install so I have to do a manual call to installutil.exe.
Let me check it.
I have just updated to Installaware X11 and the .net Installer Class function no longer works. Is there any fix for this coming?
rodm wrote:I have just updated to Installaware X11 and the .net Installer Class function no longer works. Is there any fix for this coming?
Run .NET Installer Class doesn't have any problem. The problem here is due some errors present with the setup script.
Users browsing this forum: No registered users and 44 guests
