Error in build using generic Delphi Plug-In...
jediware
Post by jediware »
Background
I am using:
* WIndows 7 64bit
* InstallAware 9 R2 (Moya.sp1.060409)
* Delphi 2007
What I did:
* Created a new project from InstallAware (Plug-Ins>Delphi Plug-In)
* Opened project in Delphi 2007, Compiled both DLLs.
* Added the following to my registry:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\MimarSinan\InstallAware\2.0\Plug-Ins\Demo]
@="C:\\Users\\Luke\\Documents\\InstallAwarePlugin\\mIDEPlug.dll"
"Action"="InstallAwarePlugin"
"Execute"="mEXEPlug.dll"
"Script"="Delphi Plug-In"
* Opened InstallAware, created a Blank Project
* Used my newly created "Delphi Plug-In" without a problem (Here is the script:)
~InstallAware Clipboard Data~
~Comment~
~{174B0BF3-FE9B-45A7-8715-17A74A614754}~
~InstallAwarePlugin~
~{6C66F791-51A1-49BA-91FB-1BAD861D9673}~
~TRUE,$TEST$~
~mIDEPlug.dll\mEXEPlug.dll~
~Set Variable~
~{D8EFA28B-628E-4FE5-999C-D93E4C52D61A}~
~TEST$MYAH$MYAH$FALSE~
~1~
* Did a "Build CD or DVD" and got the following results:
Building Project: DelphiPluginExample
Output Folder: C:\Users\Luke\Documents\DelphiPluginExample\Release\UncompressedDeployment Type: Uncompressed Directory Layout
Code Signing: Disabled
Compression: Default
Cleared output folder C:\Users\Luke\Documents\DelphiPluginExample\Release\UncompressedBuilt plug-in action InstallAwarePlugin
Built installation executable
Injected setup languages
Error during build: Some plug-ins required by your project are not available.    Please ensure all required plug-ins are installed. Run InstallAware setup and   choose Add or Remove Features, or run the third party plug-in installer.
Any idea what I am doing wrong? Thanks in advance for your assistance.
Sincerely,
Luke Lanphear
Eclipse Software Systems, Inc.
P.S. I have attached a zip file with the Delphi project, InstallAware project, registry update, etc.
PluginExample.zip
This is all projects and settings used to reproduce the problem.
(1.87 MiB) Downloaded 2057 times
jediware
Re: Error in build using generic Delphi Plug-In...
Post by jediware »
Found the solution here...
http://forums.installaware.com/viewtopic.php?f=2&t=1719
In a nutshell, the Plug-In registry Folder name MUST BE THE SAME as the Action
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\MimarSinan\InstallAware\2.0\Plug-Ins\InstallAwarePlugin]
Post by mills »
Post by mills »
You must have trained in the ways of the Jedi.
