Do you currently support the installation of SQL Server Express 2005 with SP4?
If not is there a way to include it as a runtime myself?
I appologize if this has already been posted somewhere, I was unable to find it.
SQL Server Express 2005 Service Pack 4
Re: SQL Server Express 2005 Service Pack 4
Dear pointos,
We currently support installing SQL Server 2005 SP3 only. That being said, you can install ANY msi setup you wish from your MSIcode script using out (Un)Install MSI Setup command. Are you familiar with this plug-in?
With slight tongue in cheek, InstallAware as a company usually prides itself on being quick to support the latest Microsoft products. Any idea when SQL 2005 with SP4 will be available as package?
Bob T
(in rather shaky Christchurch, New Zealand)
Bob T
Dear Bob,
Please note that you can create any runtime you want using this tutorial:
Where can I see a list of all the runtimes in the current version of InstallAware?
That would help in deciding if it's worth upgrading.
http://www.pointline.com
http://www.paraeasy.ch
http://ulrichard.ch
http://ulrichard.ch
Hi giaviv,
from what I can guess from the almost non readable screenshot, SQL Server Express 2005 Service Pack 4 is not included in the latest release.
But then, newerappruntimes.jpg has a last modified time of May 2010.
Does that imply that the runtimes didn't change in the releases since then?
Rgds
Richard
Rgds
Richard
http://ulrichard.ch
http://ulrichard.ch
The runtime list has not change since, however please note that you can create your own runtimes using this tutorial:
Users browsing this forum: Google [Bot] and 19 guests
