I am new but have been taking much time to become accustomed. One big question though, is there a way to run a variable command to see what information it produces. For example:
Set Variable CallingPath to ""
Get INI $Windir$\johndoe.ini, [Global] CallingPath Value into Variable CallingPath
Set Variable CallingPath to $CallingPath$
So, with (Get INI $Windir$\johndoe.ini, [Global] CallingPath Value into Variable CallingPath) this in mind, is there a way to see what this command produces? It would really help us ensure we are coding what we need correctly. Any help would be great and thanks for everyones time to read this!
Brandon
Showing information gathered by variable?
Re: Showing information gathered by variable?
You really don't need that last line there. The previous statement will already have updated the variable for you. I am not sure what you are asking, but you can always figure out what value the variable holds using the debugger and/or displaying the age old MessageBox
Awesome, that was exactly what I needed. Also, thanks for the info on that last line.
I now have another question regarding your answer. I see how messagebox works, but am still working on debug mode.
I have my script going through debug and it doesn't find any errors but it doesn't show me the value for the variable, what might I be missing? Does it write a log file? Just wondering where I find the variable values when using debug mode? Thanks again,
Brandon
Brandon
Did you add a variable watch?
Thanks Michael, no I did not. Where would I find it, I have been looking for it for about 30 minutes this morning.
Do you happen to know of any books about your software that are available for purchase? Thanks
Brandon
Brandon
Found the watch that was next to debug, yea I feel bad now, lol.
Any tutorials or books your could recommend would be wonderful?
Hi Brandon,
The best we have at the moment can be found in our White Papers:
http://www.installaware.com/publications-whitepapers.htm
And product guides:
http://www.installaware.com/publications-product-guides.htm
The forum here may be able to answer many of your questions as well.
Also, pressing F1 anytime while using InstallAware will bring up the context-sensitive help window.
And product guides:
Users browsing this forum: No registered users and 26 guests
