Could anyone please tell me what would be causing this error!
Error reading from file: C:\DOCUME~1\QA\LOCALS~\Temp\mia1.tmp\data\OFFLINE\60877D3C\711DDB4B\NV.MDF. Verify that the file exists and that you can access it.
The file exists but in a different folder: C:\DOCUME~1\QA\LOCALS~\Temp\mia1.tmp\data\OFFLINE\AE2BBE0B\711DDB4B\NV.MDF.
Re: Error reading from file
What version of InstallAware are you using?
Which setup command is this file a part of?
Can you reproduce this issue by removing all setup commands except the command that installs this file?
I am using InstallAware 9.
I am not positive but I believe I found the problem. In the setupmsi45 script I changd the reboot computer and resume setup to
Write Registry Persist Key HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce\$TITLE$, $EXEFILE$
Reboot Computer
because after the reboot computer and resume setup, it is aweful annoying that I can't get to anything on my desktop, there are no icons, no start menu/taskbar...
From what it looks like, when I have the write registry persist key... in code, the install doesn't recreate those temporary directories so it must lose that path after the reboot but with the reboot computer and resume setup, after the machine reboots it runs through the whole 15 minute long "verifying the contents of this setup package..." which I am assuming is recreating those temporary directories.
Reboot Computer
If you are based off of a single file installer, you should not invoke $EXEFILE$ but $SFXFILE$ because the $EXEFILE$ resources will vanish as you have found out.
Please note that you really should be calling Reboot and Resume instead of what you are doing now. Microsoft guidelines require that any setups returning after a reboot must re-invoke before explorer.exe has been loaded - thus the missing "desktop icons".
In fact, we used to have Reboot and Resume work the way you are trying to it right now manually, but had tons of complaints about that so had to change it to the current approach, which has confused you.
Users browsing this forum: Baidu [Spider] and 49 guests
